Important
Notes: Beta
versions contain new features and functions that have not yet
been as fully tested as have Release versions. If you use a
Beta, you may find bugs or problems and you are expected to
report them to Ross-Tech so that we can fix them before making a
new Release.
Beta 19.1.2 included the
following improvements:
Adds a "Whole Vehicle" choice Controller Channel Map dialog.
... this can still take quite a while, so either use
a battery charger or let the engine idle.
Support for Manual diagnostic mode changes.
... this is not something that should be played with by most users, so
exactly how
it's done will not be documented. If you need this capability, please e-mail Support and
provide details why you think you need it.
Considerably improved support for 2019 A8/Q8/A6, etc.
... some addresses were inaccessible in previous versions.
Revised Installation List retrieval
... much faster
and more exhaustive due to using broadcasts rather than sequential queries.
Completely revised and
revamped ASAM/ODX Data (DS 301)
... and changes to the VCDS software needed to accommodate it.
Over 4000 new fault code texts
... for DTCs in the latest cars.
Many other small fixes and optimizations.
... way too many to list individually.
Beta 19.4.0 includes the
Adds a new Adaptation Map file format,
'Raw Hex'
... which allows for the ability to restore all the
Adaptation channels in a control module to a previously
saved state. Restore can only be done from the new "adphex-[whatever].csv
file format, so obviously one must make a Raw Hex map before
one can Restore Adaptations from it.
Note: The Restore
functionality may not work on control modules that use the
ancient KW1281 protocol.
Adds additional checks to prevent inadvertent VIN registration.
... applicable only interfaces with
VIN-Limited licenses.
Added additional feedback UDS Adaptation Read Errors.
Expanded Diagnostic Firewall checks.
Added TDI Timing Checker support for certain marine engines.
Improved UDS SRI labels and texts.
revamped ASAM/ODX Data (DS 307)
Beta 19.4 works only with Ross-Tech's
current
HEX-NET and HEX-V2 interfaces.
It will not work with any of our older, legacy
interfaces.
Support for legacy interfaces
will be included again in the next Release version.
must be set to the Beta channel using VCIConfig.
CB v0.4501 or higher is required to use this version of
VCDS.
Updating your interface will not affect compatibility with
previous versions of VCDS.
Default installation location
is C:\Ross-Tech\VCDS-Beta\ If allowed to install to
its default location, it will not overwrite or interfere
with the use of Release 18.2.
Works on Windows 7 and newer,
including Windows 10. Either 32 or 64 bit versions of
Windows are fully supported. It might still work on XP
as well, but we no longer consider any version of Windows
older than 7 to be "supported."
The Copyright Notice,
Disclaimer, and Instructions posted on our
main download page apply to this version as well.
Beta 19.4.0
Data Version 20190411 /
DS307.0
Beta 19.x is no longer available for download.
All new features and improvements have been
incorporated into our
Current Release.
