Diagnostic Software for VW-Audi Group Cars
Loading
                Online Demo / Manual - About Screen
License Info:
  • The Serial Number will initially be Please test on car to see serial number until you have connected to a car and checked fault codes in a controller. After you have done this, you will have a Serial Number composed of letters and numbers.
  • License Status should always be Valid / Activated, with all of our Current Interfaces since they store their own activation. If it says Not Tested, then you will need to connect to a controller (like 01-Engine) and for example check Fault Codes. Afterward, the Serial Number should be visible.
On this screen, you will also find a Copyright Notice, License info, and Contact Information.   The Web and E-Mail "links" open up your default browser or default email program, respectively and can be used if your PC is connected to the Internet.
To return to the Main Screen, click [Go Back].
Unless otherwise noted, all content on this site is Copyright (c) 2000-2017 by Ross-Tech LLC.  All rights reserved.
