This function cycles
through each possible address in the vehicle, finding each controller
and reporting its Address, Name, Protocol, VAG Number, Component Number, Soft.
Coding, and Work Shop Code.
Note: No one car has all Modules! Newer cars have more, older cars have
fewer.
[Start]
This begins the finder. Beware; a "full" scan can take 45 minutes or
more. Of course, you can scan selected address ranges.
If you check Use CAN Only
then the Module Finder will not check for any modules on the
K-line.
[Stop]
This stops the finder.
If you close the Finder
dialog, any data in its output box will be lost. If you would like to
keep a record, click the [Copy] button first, then you can then paste the results
into the application of your choice, such as MS Word or Notepad.
[Save]
saves your results to a file in your VCDS\Logs directory
[Clear]
erases your results.
To return to the Main Screen, click
[Close]
The output from our 2008 Audi A5 looks like this:
http://www.ross-tech.com/vcds/tour/908/module-finder-result-A5.txt
