The
7-digit PIN/SKC (Secret Key Code) dialog is used for Key
Matching and Immobilizer 3 Adaptation.
See this page
for instructions for each procedure and immobilizer type:
Common Diagnostic
Procedures
Important Note:
Unless you ALREADY have the SKC information for your vehicle
and components then you will NOT be able to do any of the
Immobilizer functions.
Click this link for more information.
You must
enter the following information:
7-digit SKC
that the dealer generated for your exact Immobilizer ID
Number.
Date on
which the 7-digit SKC was GENERATED BY THE DEALER.
Workshop
Code (WSC) for the dealer that generated the SKC.
Importer
Number for the dealer that generated the SKC.
The 7-digit SKC is useless without the other
three items.
When you have
filled in all of the data click
[OK].
If any of the entered data does not make sense, the following
message may appear:
When you
have successfully submitted the 7-digit PIN/SKC, you are
taken back to either the Login or Adaptation screen
(wherever you were when you clicked on [Use 7-digit PIN/SKC] ). Now, you should have
“XXXXX” in Login or Adaptation value.
Unlike
the factory diagnostic tools, with VCDS-Lite, the same PIN
can be used for a particular car at any time in the
future, as long as you keep track of the PIN, along with
the Date on which the PIN was GENERATED BY THE DEALER,
the dealer's Workshop Code (WSC) and the Importer number.
If you
obtain a 7-digit SKC, but the dealer has not provided the
WSC, look at the window stickers of vehicles on the
dealer's lot. The dealer number will be listed next to the
name and address of the dealer. In the US, the dealer
number will be a 4 followed by five more digits, for
example 401742. To obtain the WSC, delete the 4 and simply
use the remaining five digits, 01742 in the above example.
The
Importer number should be:
444 for all dealerships in the US
999 for all dealerships in Canada
995 for all dealerships in France
See this page for important
SKC information.
Use the
[OK] button to save the 7-digit information and return to
Use the
[Cancel] button to return to the Login or Adaptation
screen without saving.
