Windows Based VAG/VAS Emulator
Version: Release 607.x
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Sunday,09,July,2006,11:44:30
VIN Number: WVWRU73C57Exxxxxx License Plate: ABC 1234
Mileage: 99991 Repair Order: R060709-1234
Control Module Part Number:
03H 906 032 B
Component and/or Version:
P3.6-FSI-LEV2
G00 8744
Software Coding:
0000175
Work Shop Code: WSC
05311
7 Faults Found:
008851 - Fuel
Pressure Regulator Valve (N276): Mechanical Malfunction
P2293 - 002 - Lower Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100010
Fault Frequency: 8
Mileage: 3641 km
Date: 2006.06.30
Time: 08:10:39
RPM: 626 /min
Load: 44.7 %
Temperature: 86.0°C
Temperature: 45.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
000768 -
Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
Fault Status: 11100001
Mileage: 3641 km
Date: 2006.06.30
Time: 08:10:41
RPM: 713 /min
Load: 39.6 %
Speed: 2.0 km/h
Temperature: 82.0°C
Temperature: 49.0°C
Voltage: 13.462 V
000769 - Cylinder
1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
Mileage: 3641 km
Date: 2006.06.30
Time: 08:10:42
RPM: 736 /min
Load: 40.8 %
Speed: 2.0 km/h
Temperature: 82.0°C
Temperature: 49.0°C
Voltage: 13.589 V
000771 - Cylinder
3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 3641 km
Date: 2006.06.30
Time: 08:11:25
RPM: 1550 /min
Load: 22.0 %
Speed: 34.0 km/h
Temperature: 86.0°C
Temperature: 40.0°C
Voltage: 13.970 V
000770 - Cylinder
2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Mileage: 3641 km
Date: 2006.06.30
Time: 08:11:25
RPM: 1550 /min
Load: 22.0 %
Speed: 34.0 km/h
Temperature: 86.0°C
Temperature: 40.0°C
Voltage: 13.970 V
000773 - Cylinder
5: Misfire Detected
P0305 - 002 - Lower Limit Exceeded - Intermittent
Mileage: 4275 km
Date: 2006.07.07
Time: 12:12:53
RPM: 2369 /min
Load: 29.4 %
Speed: 69.0 km/h
Temperature: 87.0°C
Temperature: 36.0°C
Voltage: 13.970 V
000312 - Oxygen
(Lambda) Sensor B1 S2: Signal too High
P0138 - 001 - Upper Limit Exceeded - Intermittent
Fault Status: 00100001
Mileage: 4276 km
Date: 2006.07.07
Time: 14:02:40
RPM: 572 /min
Load: 27.8 %
Speed: 3.0 km/h
Temperature: 84.0°C
Temperature: 51.0°C
Voltage: 13.589 V
Readiness: 0000
0000
