Windows Based VAG/VAS Emulator
Version: Release 303.1
Dealer/Shop Name: Ross Diagnostic Service
Workshop Code: 000 00000
Self-Diagnosis Log
Wednesday, 02 April 2003, 13:03:48
VIN Number:
WAULT68E32A038957 License Plate: ABC 1234
Mileage: 12792 Repair Order: R30402001
Chassis Type: 8E - B6 Audi A4
Scan: 01,02,03,08,09,15,16,17,36,37,45,46,55,56
Address 01 -------------------------------------------------------
Controller: 8E0 909 559 D
Component: 3.0L V6/5V G 0002
Coding: 0016711
Shop #: WSC 63351
1 Faults Found:
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 001 - Upper Limit Exceeded - Intermittent
Readiness: 0110 1101
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04495
Shop #: WSC 06435
1 Faults Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 G
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0204
Coding: 00011
Shop #: WSC 63351
0 Faults Found:
Self-Diagnosis Log
Page 2
VIN Number: WAULT68E32A038957 License Plate: ABC 1234
Address 15 -------------------------------------------------------
Controller: 8E0 959 655 A
Component: Airbag 8.4E 3000
Coding: 0010607
Shop #: WSC 63351
0 Faults Found:
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
1 Faults Found:
52-10 - Supply Voltage Too High - Intermittent
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D22
Coding: 03200
Shop #: WSC 00066
WAULT68E32A038957 AUZ6Z0A0166743
1 Faults Found:
01304 - Radio
Address 36 -------------------------------------------------------
Controller: 8E0 959 760
Component: Sitzmemory R2 F 0201
Coding: 00002
Shop #: WSC 63351
07-10 - Signal to Low - Intermittent
06-10 - Signal to High - Intermittent
79-00 - Please Check Fault Codes
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
0 Faults Found:
Self-Diagnosis Log
Page 3
VIN Number:
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 T
Component: Komfortgerát T5B 0616
Coding: 11848
Shop #: WSC 63351
7 Faults Found:
37-00 - Faulty
01331 - Door Control Module: Driver Side (J386)
01332 - Door Control Module: Passenger Side (J387)
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00060
Shop #: WSC 63351
1 Faults Found:
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 A
Component: symphony II NP2 0004
Coding: 00201
Shop #: WSC 63351
0 Faults Found:
End -------------------------------------------------------
