Product
Information
Interfaces
KII-USB
Micro-CAN
HEX-COM+CAN
HEX-USB+CAN
USB Driver Installation
Micro-CAN
CAN-only <-> USB Communications Interface
Click for larger picture |
Low-cost interface designed exclusively
for use on cars based on Mk.5 Golf technology. See list of compatible cars below. This
interface is not backwards compatible with older cars using K-lines for diagnostics, and it is not compatible
with some Audi models.
Acts as a "dongle". A
license for VCDS is embedded in this this interface, so VCDS is
will always be always
fully-functional on any PC that meets our
requirements.
USB connector plugs into most modern
laptops! (USB 1.1 or 2.0)
Bi-Color (red/green) status/activity
LED
12 month guarantee against defects.
This interface comes with an OBD-II type connector which plugs directly into all VW,
Audi, Seat, and Skoda cars which are compatible with this interface.
Compatibility:
This interface is compatible only with cars based on Mk.5 Golf technology.
If your car's chassis type isn't on this list, it's not compatible with this
interface! All of these chassis-types
are the latest generation of that model.
Previous generations of the same model are not compatible
and should use a KII- or HEX- series interface instead.
If you're not certain, please check your car's VIN.
The 7th and 8th digit have the chassis code. For example: WAUMF78P06A0NNNNN is an 8P-chassis
Audi A3.
Computer Requirements:
We recommend at least a 1 GHz
Pentium-3 (or AMD equivalent) with 128 MB of RAM and Windows
XP or newer. Windows Vista or 7 on a machine robust
enough to support the respective operating system are also
fine.
As of version
10.6, we no longer support Windows 95, 98, ME or NT4.
If you're using a PC that has a CPU speed less than 1 GHz
and which has a Serial port, then you should consider the Serial HEX-COM+CAN
instead.
The cable on this interface is about 6 feet long -- just
right for most laptops. The
USB standards
do not allow for passive extension cords!
We have tested many Active USB extensions and have found one
that works. You can order the
16-ft Active USB Extension from our
Store. We do not sell
or support any other brands or models of USB extensions, if
you have problems when using one, the first thing
we're going to tell you is to eliminate the extension.
Resale:
The Micro-CAN
acts as a "dongle" for VCDS, so
VCDS should be fully functional on any PC when used with
this interface. However, product support is provided only
to the original purchaser.
If you buy a second-hand Micro-CAN from someone and want support, you'll still need to pay
$99 to register.
Software:
The Micro-CAN must be used with
a current version of VCDS.
It does not work with VCDS-Lite.
This interface
requires a special driver to be installed on your
PC. It does not emulate a COM port.
That
means this interface will not work with any other
software besides VCDS.
We do
not sell any interfaces as a "Stand-Alone" products.
We only sell them with
our VCDS software.
Driver
Installation:
Click
here for complete driver installation instructions.
Click here to order a Micro-CAN
from our Store.
Product
Information
Interfaces
KII-USB
Micro-CAN
HEX-COM+CAN
HEX-USB+CAN
USB Driver Installation |
